what to offer? i offered $200
Old Aug 20, 2008 | 10:46 PM
shank0668's Avatar
Default what to offer? i offered $200
what would be a good offer and what will it cost to repair[see item discription] they have irs in 99 right?
Old Aug 20, 2008 | 11:06 PM
700 sportsman's Avatar
your link didn't work or what link/description are you talking about??
Old Aug 20, 2008 | 11:15 PM
shank0668's Avatar
http://cgi.ebay.com/ebaymotors...rdZ1QQsspagenameZWDVW
lol i didnt post it
Old Aug 21, 2008 | 01:03 AM
shank0668's Avatar
The hours gauge does not light up so I dont know,it is my daughters and she thought it was some where around 200hrs.As far as i can see,it needs some wiring for the stator,something done on the starter,it wont turn over.the pull starter is broke.the front driveshaft from transfer case to front diff.will need replaced.the frame has some surface rust so a good cleaning. all the body parts are unbolted so it will need put back together,A new headlight and probably a new speedo
theres all the issues so how much will it cost to get all the parts i need? and how much should i offer? should i stay away from this? what parts do i need?
Old Aug 21, 2008 | 07:28 AM
user493's Avatar
Moto Psycho
ALL Sportsman 500s have IRS. If everything was okay it would be worth 4 times that much. I guess it's worth it if you like working on it and have time to do it.
Old Aug 21, 2008 | 08:28 AM
MaineWheeler's Avatar
Locally(Turner) here in Maine we have a guy that has a 04 500 sportsman with 740miles that the right front strut&a-arm were ripped right off of machine and other then that & front rack/light, it starts right up, sounds excellent and all plastic is in excellent shape and he only wants 1000. so I wouldnt give more then a couple of hundred for it. i think at the 610 the bids at is already 400 too much. But thats me.
Old Aug 21, 2008 | 01:10 PM
shank0668's Avatar
he said he will take 1000 for it and that 300-500 in repairs
Old Aug 21, 2008 | 01:22 PM
shank0668's Avatar
oh and thats by repair by me/ a 12 year old. ill give it a shot if i get it and if i cant figure it out thats whats my dads for
heres another thing about it.
I am not sure on the transfer case,The original owner for some reason tack welded the front shaft onto the transfer shaft.it looks like it could be grinded off. I think the estimate that I had last time was around 300 to 500 depending on what couldbe saved.if you are asking if my daughter would take 1000, yes she is looking to get about that much. thank you.
why would the shaft be welded to the transfer case and should i stay away from this one?
Old Aug 21, 2008 | 02:47 PM
A couple of guys I know tack welded theirs also and the reason was because they had a wobble & rattle to it that no matter what they did they couldn't get rid of it and it was not so much the wobble as the annoying rattle that accompanied it. They tacked it and never had another problem. I'd take a real good look at it because it could have been done for the same simple no mechanical problem reason.
Old Aug 21, 2008 | 02:55 PM
shank0668's Avatar
he said frame has some surface rust so what will i have to do with that. oh and i have to replace the drive shaft if i get it so that might be a bit**
