warrior with no spark
Old Aug 20, 2008 | 11:42 PM
atvnewbee's Avatar
Default warrior with no spark
have a 1991 warrior. I am getting no spark. coil cap,coil,and all switches ck. ok . The book is telling me that the pick up coil is bad(ohm reading not at spec.) has any one had this problem. thanks
Old Aug 21, 2008 | 07:37 PM
cadillacdude1975's Avatar
if you tested the coil properly, then that should be the problem. id check everything else too while you are testing. if the pickup coil is in fact bad, the quad wont get the juice to make the spark. you can try to start it all day, but you wont get anywhere.
Reactant
Mar 30, 2022 02:08 AM
STLyamwar
Jul 25, 2020 04:44 AM
manuelrivera
Aug 8, 2015 04:34 PM
suzukiquadrunner1987
Aug 6, 2015 05:29 PM
Ashley S
Jul 31, 2015 09:46 AM
