Sport Quads Discussions on sport quads.
I need help with my axel carrier...any tips would help
Old Aug 21, 2008 | 02:29 AM
TheRipper13's Avatar
Default I need help with my axel carrier...any tips would help
I am 99% sure i need to replace my bearings in the axel carrier. I am having trouble getting the axel nut off, and once i do that, i have no idea what to do!!! Any tips would help, where to buy, what to do....anything!!!!!!!
Old Aug 21, 2008 | 05:01 AM
user493's Avatar
Moto Psycho
What year, make, and model?
Old Aug 21, 2008 | 01:12 PM
2003 Honda 400ex
Old Aug 21, 2008 | 02:46 PM
kukerdan's Avatar
http://forums.atvconnection.co...&keyword1=400ex%20axle
Old Aug 21, 2008 | 02:50 PM
kukerdan's Avatar
http://forums.atvconnection.co...548902&highlight_key=y
Old Aug 21, 2008 | 02:58 PM
kukerdan's Avatar
As far as the axle nuts, They were easy on my 300, because it was in good shape, but a bitch on my scrambler..
I reccomend the biggest adjustable wrench you can find, 15 - 18 " in length, lots of P blaster , or wd 40 or liquid wrench.
or freeze off.
or all 4
put a big pipe on the end of the wrench and pull down..
clean the threads in front of the axle nuts with a wirebrush too, this will help.
you should be spinningto the left to back them off, than theres a Clip you have to pop off,
than everything slides off to the right, and the axle out to the left..
the carrier pops out to the left also, use liberal wd-40 when taking it out,
make sure you clean the **** out of everything
getting thebearings out might be a bitch, you can try tapping them out from the inside, and as far as pressing new ones in
unless you have a press, or a workbench Vice, its not going to be easy, with a press / vice, just line stuff up straight,
and use makeshift shims of around the same size as the bearing but slightly smaller, to push it in.,
Old Aug 21, 2008 | 07:35 PM
sweet. thanks a lot man. Hopefully this will work out. Thanks again.
exmotocrosser
Sep 26, 2015 08:18 AM
MikeyBoyesq
Sep 22, 2015 10:02 AM
cornermike
Sep 10, 2015 08:30 AM
Stever6368
Aug 16, 2015 07:34 PM
Technical and How-To Articles
Jul 2, 2015 01:34 AM
