scrambler 2001 500 4x4 ball joints
Old Aug 21, 2008 | 11:32 AM
kukerdan's Avatar
Default scrambler 2001 500 4x4 ball joints
Hey, I just got my long travel struts here,
How should the ball joints feel?
They seem to move around ok, althought it seems really easy,
I can tug maybe a millimeter or two outward on the stud, it has a tiny
bit of play that way, but it pulls back in when i let go.
also, how am I suppose to tighten this thing? the stud spins around
with no resistance?
Old Aug 21, 2008 | 01:05 PM
Gee3's Avatar
Sounds like they are fine. They should move freely. That millimeter or two of play is normal on a used machine.
The stud is tapered and will seat inside a matching taper inside the A arm when you tighten up the castle nut. This will hold it from spinning when you tighten it.
Old Aug 21, 2008 | 01:17 PM
MECHANIKE's Avatar
hey,kukerdan,what i do is put the floor jack on the a arm,which pushes it tight on the taper.......
Old Aug 21, 2008 | 01:28 PM
kukerdan's Avatar
ok, so no need to buy new ***** joints? Am I going to notice that slight play?
It honestly might not even be a millimeter.. the ball seems tight, where the stud goes in i can move up and down the tiniest bit, hardly enough to see, but i can feel it
Old Aug 21, 2008 | 01:34 PM
MECHANIKE's Avatar
mine has more,grease it,does that take up the space? it does mine.when i put togather mine it had no play.......
Old Aug 21, 2008 | 02:19 PM
kukerdan's Avatar
cant find out now , in an office...
How good are the polaris parts?
If i need them, i can pick them up at the stealer for 31$ a pop,
or i can order moose, or epi standards for about 19$ a pop, or epi heavy duty for 34 or so.
Old Aug 21, 2008 | 04:29 PM
kukerdan's Avatar
Well, I got mixed opinions on who I asked.
They look pretty ugly,
I feel slight grinding in there
and I can pull up on them a bit.
My uncle who has been a mechanic for 20 years says they are shot
if they have any play.
So I went and ordered all ***** replacements direct from allballs,
19 a piece and 7 shipping, not bad.
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
exmotocrosser
Sep 13, 2019 06:12 AM
35dodge
Sep 29, 2015 09:40 AM
Matt123
Sep 29, 2015 01:29 AM
exmotocrosser
Sep 26, 2015 08:18 AM
