o5 sportsman 400
Old Aug 21, 2008 | 03:18 PM
sportsman40005's Avatar
Default o5 sportsman 400
I have a o5 sportsman 400. I have been having problems with the engine cutting out ( or missing) when It gets in a hard pull in mud or climbing a hill. I have a service manual but, as far as I can determine , there are no carb fuel adjustments. The spark plug is sooted up like it's burning to rich or not enough spark. Air filter is new & no restrictions in air flow. New spark plug same problem.. Any suggestions on what to look for / check ??
thanks,
ken
Old Aug 21, 2008 | 03:36 PM
colt2245p's Avatar
they had issues with the jetting on these......you need a smaller jet....do a search and you will find several post regaurding this....i think the size was a 140 or a 142.5 that you need.
Old Aug 22, 2008 | 08:54 AM
Thanks pro rider. can you assist me as to how I would go about doing a search to find this information
Old Aug 22, 2008 | 11:13 AM
oldsmoboat's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: sportsman40005
Thanks pro rider. can you assist me as to how I would go about doing a search to find this information</end quote></div>
Click me
Old Aug 22, 2008 | 03:28 PM
well, I called the dealer about a smaller carb jet. Polaris dealer/ parts man says that there is only 1 jet offered for the carb. I think he said it's a .5 ( if that souds right) Whre would I find a smaller jet. They are telling me to check the spark.
Thanks for the click me.
I typed in carb jet for polaris 400 & it didn't come up with any results. Any ideas ??
Old Aug 22, 2008 | 03:31 PM
oldsmoboat's Avatar
Find a different dealer. They don't know what they are talking about or they are lying to you. Either way, not a place I would want to deal with.
Old Aug 22, 2008 | 07:33 PM
I found on the web site that a 05 sportsman 400 comes stock with a 172.5 main jet
If the 140 or the 145.5 is correct. Then, this would be alot smaller than the stock main jet.
I'am still looking around on the web to locate a jet kit
Old Aug 22, 2008 | 11:53 PM
oldsmoboat's Avatar
http://forums.atvconnection.co...96390&highlight_key=y
http://forums.atvconnection.co...526446&highlight_key=y
Old Aug 23, 2008 | 12:14 AM
Hey, thanks for link. Weren't you the one having the same problems in the link ? Did the re jetting fix yours. If so, did you also have to change out the needle to match up with the smaller main jet.
Old Aug 23, 2008 | 08:12 PM
oldsmoboat's Avatar
Re-jetting solved it.
