84 honda 250r need help
Old Aug 21, 2008 | 09:32 PM
wildhoghunter's Avatar
Default 84 honda 250r need help
last night i fouled 3 plugs in a hour today i noticed the bottom end was full of gas at wide open throtle carb sprays gas out the back can any one help
Old Aug 22, 2008 | 11:53 AM
rldbobcat's Avatar
I would guess your float is stuck and not shutting fuel off. take the bowl off the carb and move float up and down and make sure it shuts off the fuel when it is at the top. If not you need to bend the tab so the fuel shuts off when the float is up. There should be a carb float measurement but I am not sure what it is on the 250R.
Old Aug 29, 2008 | 11:35 AM
scary132's Avatar
Clean your carb good (as in remove it from the bike, take it apart, and blow out all the passages with compressed air). Check the float valve for wear.
Old Aug 30, 2008 | 07:17 PM
thanks for the help the float was the problem
stcspiderman
Sep 13, 2015 05:15 PM
Alex Rodak
Sep 13, 2015 12:30 AM
Alex Rodak
Sep 12, 2015 09:39 AM
Alex Rodak
Sep 11, 2015 11:42 PM
Jason Campbell
Sep 7, 2015 02:25 PM
