Winch Question
Old Aug 22, 2008 | 05:56 PM
HEMIsphere's Avatar
Default Winch Question
I just got a brand new 08 800, and the Polaris winch. I installed the winch, unspooled it and then wound it back up under the weight of the machine. A few days later I went to drag out an old front mount tractor snow blower. I hit the in side of the switch and all I got was clicking at the contactor. So now I am pissed, I have 20' of line out and I can't spool it back up. I coil it back up and start riding to the garage, at the same time working the switch. Suddenly it starts working, so I go back to the shed and hook it back up and again nothing just clicking. Could it be that there is not enough juice to work the winch while idling? I gave it some throttle and was able to drag out the blower. Any ideas?
Old Aug 22, 2008 | 06:00 PM
KyleP's Avatar
my winch works with the engine off.
Old Aug 22, 2008 | 07:13 PM
HEMIsphere's Avatar
Mine does not, I have to have the ignition in the on position.
Old Aug 22, 2008 | 07:28 PM
KyleP's Avatar
yea I have to have the ignition in the on position also but I am saying the engine does not have to be running.
Old Aug 22, 2008 | 09:19 PM
700 sportsman's Avatar
yeh, but it really drains your battery if you don't have it runnning
that is kind of a weird problem, someone will chime in with some info
Old Aug 22, 2008 | 09:29 PM
sled05's Avatar
I had the same exact problem with my two month old Venom.If I played with the switch it would finally pull in. They shipped me a new contactor and all is good. But first I would check all connections.
Old Aug 22, 2008 | 10:17 PM
Mikka's Avatar
the conctactors that come with the Polaris winch is not very reliable. When I bought my 800 they installed me a a warn winch but put in a polaris contactor. It did not last one month. I had them to replace it with an original warn and no problem since.
It I were you, I would even pay the difference in cost to have a warn contactor installed instead of the Polaris. Both are almost identical except that the Polaris one is an offshore copy of the warn.
Old Aug 22, 2008 | 10:37 PM
HEMIsphere's Avatar
I tried it again tonight and had the same problem. I grabbed my DVOM and check the battery voltage when I hit the switch to see if how the voltage dropped. It only dropped a few tenths of a volt but while checking the voltage I found my problem. Polaris gives you a longer bolt to connect the wires to the battery, well the bolt is to long so the connection was bad. I could freely move the positive wires around. I put in some washers and all is good. I am going to dig out the original bolt and put that back in.
Mikka you would'nt have a part number or give me a link to the Warn contactor would you?
Thanks to everyone.
Old Aug 22, 2008 | 11:19 PM
Mikka's Avatar
http://warn.iwebcat.com/_Membe...okups/partdetail.asp.
This should be the one.
Old Aug 23, 2008 | 02:53 AM
19TankHead60's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: HEMIsphere
</end quote></div>
Man I didn't realize that was gonna be the solution. I had just put mine in a couple weeks ago. And when I went to put the longer bolt in I could see the terminal starting to flex on one side as soft as it is. So i just used the original bolt too. Good to hear you on top of everything and found it yourself. [img]i/expressions/face-icon-small-cool.gif[/img]
ylomnstr
Sep 22, 2015 12:19 AM
Rick Van Matre
Sep 11, 2015 11:52 PM
ylomnstr
Sep 10, 2015 06:45 AM
chewy78
Sep 8, 2015 10:37 AM
ylomnstr
Sep 4, 2015 05:02 PM
