ds 650 running problem
Old Aug 24, 2008 | 09:51 PM
02ds650maine's Avatar
Default ds 650 running problem
after riding fine all day it the pit when i start it back up to leave it would idle fine but when i gave it throttle it would poop and die. it will idle fine. i tried draining the bowl three times but that didnt help at all. if the choke was pulled it would just die as well. what should i do? im guna start with new plugs but thats all i know. please help thanks
Old Aug 24, 2008 | 10:19 PM
cynick's Avatar
Have you tried taking the bowl off and clean the pilot jet?
Old Aug 25, 2008 | 01:15 AM
McKay5858's Avatar
my money is on a loose ground wire. i know most quads run without a battery once there started but not the ds. i had the exact same thing happen to me once, drove me up a wall had to idle all the way home and it was just a bad connection on the battery
Old Aug 25, 2008 | 08:28 PM
if it was just a dead batttery would it cause it to act like that? so hopefully if i just get a new batt that will solve the problem? thanks
Old Aug 25, 2008 | 08:30 PM
AZSAND's Avatar
THAT!!!!!Sounds down right sexy!
Did you try runnig it with the gas cap off
Old Aug 25, 2008 | 09:01 PM
at the time i had it runnig i didnt take it off but i did after to see if it was vapor locked or something but it didnt change. i also checked my tank vent hose and that was fine
Old Aug 25, 2008 | 09:03 PM
AZSAND's Avatar
PULL THE CARB AND CLEAN THE JETS
Old Aug 25, 2008 | 10:12 PM
McKay5858's Avatar
do you have a multi meter? check the ground to see if its got a good connection. when my ground wire was loose it would idle all day long smooth as ever but as soon as i hit the gas it would just die the same way as you describe. my battery wasnt dead jsut a bad connection
Old Aug 27, 2008 | 04:28 PM
Todem's Avatar
I'm with CYNICK and AZSAND. Probably a blocked pilot jet. Very common.
Old Aug 28, 2008 | 07:14 PM
so the problem was def the battery soon as i put the new one in it started right up and ran fine! thanks for the help
