tire swap
Old Aug 25, 2008 | 07:49 PM
LArebel29's Avatar
Default tire swap
ok so i have an '07 420 and everything is stock we have something going on around here called mudfest and i wanted to put some new tires and rims on before but i cant afford it right now...so one of my buddies that has a grizz 700 said he would let me use his set...which are 27x10-12s mud lites and aftermarket rims not sure?...i know the lug pattern will fit but what about the clearance?
Old Aug 25, 2008 | 09:28 PM
Loghead's Avatar
Default tire swap
Unfortunately, probably not. You might tuck the 27's under the fenders, but they will rub on the first good hit. You can normally put 26's under without a lift, but you should have 2" of lift with 27's.
Old Aug 26, 2008 | 12:24 AM
action450s's Avatar
Default tire swap
27's are going to be real big on a stock 420, and the grizz rear wheels are the wrong offset so thats going to pose a major clearance issue for sure.
JackTheKing
Sport Quads
Nov 4, 2019 06:06 AM
black_thunder
Sep 20, 2015 10:21 PM
MikeyBoyesq
Sep 7, 2015 10:44 PM
