2005 Yamaha Grizzly 600
Old Aug 26, 2008 | 01:41 PM
jjk260's Avatar
Default 2005 Yamaha Grizzly 600
I have an 05 Grizzly 600. Sometimes when I get into mud or deeper water, the thing totally bogs down. It's like it hits the limiter when you are in reverse and really dont do much. Has this ever happened to anyone?!?! Or do you know what I should do?
Old Aug 26, 2008 | 01:56 PM
Krait's Avatar
Well first of all, is it a 600 or 660? Yamaha didn't make the 600 in 2005. If its a 660, check your electrical connections down on the front diff and put die electric grease on them. Also check your spark plug connection and die electric grease that as well. Another thing it could be is steam from the hot engine hitting water is entering the airbox and choking the engine. Modify side panels to allow more airflow, or some ppl have had luck rejetting.
Hope this helps...
Old Aug 26, 2008 | 03:04 PM
jjk260's Avatar
yes, it is a 660, didnt mean to put 600. Would the electrical make it bog and hit the rev limiter like that?
Old Aug 26, 2008 | 03:13 PM
Krait's Avatar
Well the connections on the front diff are for difflock. When they get wet they can 'fool' the ecu into thinking it is in difflock, and therefore activates the rev limiter. I have heard of it happening on 660's, as well as the other things I mentioned. Not a guarantee, but definately a possibility.
Old Aug 26, 2008 | 03:31 PM
jjk260's Avatar
ok, that makes sense. I will definitely look into these things and see if they solve the problem. thanks for the help!
Old Aug 26, 2008 | 03:49 PM
Krait's Avatar
No worries.
Old Aug 26, 2008 | 07:31 PM
Hebs's Avatar
were u using the reverse rev-limiter as an example? Or were you saying you are having the problems in reverse?
Old Aug 26, 2008 | 09:17 PM
wildwest1011's Avatar
My bruin used to do that..dielectric in the spark plug boot and it was good as new again.
Old Aug 27, 2008 | 06:26 AM
Krait's Avatar
Ha, yeah thx Hebs, I totally read that a different way...if it is hitting the rev limiter while in reverse, then yes there is a limiter there and you will need to over ride it via these instructions:
http://www.grizzhopper.com/04RevLimO-R.html
If its bogging down going forward and acting like its in reverse, then my above recommendations still could apply...
Old Aug 27, 2008 | 07:10 AM
<div class="FTQUOTE"><begin quote>Originally posted by: Krait
<a target=_blank class=ftalternatingbarlinklarge href="http://www.grizzhopper.com/04RevLimO-R.html
">http://www.grizzhopper.com/04RevLimO-R.html
</a>
If its bogging down going forward and acting like its in reverse, then my above recommendations still could apply...</end quote></div>
yep..i read it wrong as well
