Replacement Swing Arm Bolt for 400ex
Old Aug 31, 2008 | 03:02 PM
OutRacing's Avatar
Default Replacement Swing Arm Bolt for 400ex
Hey every one. I was just wondering, I for some reason, keep braking the nut end off my swing arm bolt. I use a troque wrench every time I replace it, but it still brakes. I unlike every one else who has a 400ex, have never had a swing arm bolt get stuck? Although, at 35 bucks a pop, I was wondering if any one had any ideas? If I knew the metric size of it, I might try some thread rod or see if I could find a generic bolt instead of a honda extream cost mark up bolt. Any input is greatly appriciated!
[img]C:\Documents and Settings\Adam Haas\Desktop\bolt.jpeg[/img]
Old Aug 31, 2008 | 05:05 PM
mannyj's Avatar
could try an atv salvage yard or even ebay to get that bolt at a lower cost. problem with the salvage yard is they may not have the part and ebay is the shipping time.
is the swing arm binding or do you even know what the posible problem is?
Old Sep 1, 2008 | 01:24 AM
OutRacing's Avatar
I tried to post a picture. The bolt brakes clean off right at the nut and frame. It is such a clean brake it almost looks like it is supposed to be that way. Everything on my quad is in perfect working condition. The swing arm moves like it is supposed to with no binding or tight spots. I just must ride so hard that some how, I am braking this bolt off. I have replaced this thing 5 times in the past year and a half. It is not a big deal, it is very non labor intensive and only takes a couple of minuets, it is just that it keeps happening? I would like to stop spending money on a part of my quad that should last until it rusts out. Anything that I get from a salvage yard is going to be very used, grooved, abused and most likely mushroomed really bad from where it was beat to be removed. Ebay is suprizingly slightly more expensive then the dealer. And by the time you add shipping cost it is just no good at all. Service honda is like five bucks cheeper, but they will charge 8 bucks to ship. If I could only figure out the size of this thing, I could try like some thread rod from home depot or just see if I could find or order a generic bolt.
Old Sep 1, 2008 | 02:00 AM
Williebee's Avatar
You could take the bolt to an Industrial Supply Store and see if they have heavier grade bolt that will fit your quad , it's worth a shot i've done this on lawn and garden equipment !......
Old Sep 1, 2008 | 11:45 AM
mannyj's Avatar
like williebee says just take the bolt with you and some one will be able to help you fint the right size. i believe that all-thread would be a bad idea do to the fact that its a softer grade then the swing bolt
Old Sep 1, 2008 | 12:08 PM
OutRacing's Avatar
Yeah, that is what I was thinking. I really didn't want to pull it out until I had a replacement. It is still holding everything together. But beggers can't be choosers I guess!
Old Sep 6, 2008 | 01:35 PM
Quadhog83's Avatar
I get those bolts from Service Honda for less than 25.00.Are you sure your pivot bearings arent shot?
Old Sep 6, 2008 | 01:39 PM
Quadhog83's Avatar
BTW,I have one here in my hand and it appears to be a 12m x 275mm flange bolt w/ 20mm of thread.
Old Sep 6, 2008 | 03:35 PM
ATV24/7's Avatar
Are there any aftermarket companies that make one stronger? it may be expensive but after breaking it again it could pay for itself.
Old Sep 6, 2008 | 03:36 PM
ATV24/7's Avatar
found this on LSR Racing
http://www.lsracing.com/honda-400ex-parts.htm
