06 rancher pulls to the right
Old Sep 1, 2008 | 09:43 AM
martyb1965's Avatar
Default 06 rancher pulls to the right
My 2006 Rancher pulls to the right real bad, when I look at it from the front the the front wheel on the left looks like it is cocked out a bit. is there an adjustment I can make to pull that tire in. I noticed it last night when I went for a quick ride on the street. I did just put new tires and wheels on it. Thanks for your help!!!
Old Sep 1, 2008 | 10:51 AM
JeffinTD's Avatar
Does it actually pull, like you have to fight the bar to keep it straight, or is it just that the bars aren't straight while the machine is going straight ahead?
First thing, check the tire pressures. Second, you may have bent a tie rod (if so, replace it).
Generally Honda specs a toe-out as measured at the tread of the tires (mark the backs of the tires with a gauge, rolll the machine forward until the marks are on the front, set the gauge against the marks and measure the difference).
I think alignment spec is acutally listed in the owner's manual in the last part of the maintaince section.
Once the toe-out is correct, you can also tweek the tie rod adjustment, running one out a little and the other in a little, to maintain the same toe but get the bar straight.
Old Sep 1, 2008 | 03:06 PM
martyb1965's Avatar
Yes, it pull fairly hard to the right! I don't notice as much on dirt as I do when Im on the street, and I idin't norice at all untill I put new rims & tires on it!
Thanks
Old Sep 1, 2008 | 05:15 PM
Gimpster's Avatar
Like stated, check the toe adjustment.
Also, make sure air pressures are the same. If it still pulls when both toe and pressure is set, check if one tire is taller than another. Now and then a rear tire will be taller than the other rear and make a pull occor
----- Gimpster -----
Cummins Driver
Sep 11, 2019 01:22 PM
SDR-II
Sep 29, 2015 01:06 AM
MikeyBoyesq
Aug 10, 2015 11:11 AM
Lpshann
Sport Quads
Jul 29, 2015 08:11 AM
Scottma518
Jul 16, 2015 09:19 PM
