2002 foreman (reset procedure)
Old Sep 1, 2008 | 07:56 PM
Hank5697's Avatar
Default 2002 foreman (reset procedure)
Do any of you guy's know how to reset the foreman besides unhooking the battery? I heard there is some way of using the shift buttons in sequence or something of that nature.
Old Sep 2, 2008 | 11:16 PM
Gimpster's Avatar
Only if it is a Rubicon can the system be reinitialized
A foreman 450 has the ability of checking codes and erasing them with shift switches only.
Pulling the battery cables will only reset default readings in the ECU. The system must be initialized for a Rubicon to shift correctly
----- Gimpster -----
Old Sep 3, 2008 | 07:30 AM
HondaMechanic's Avatar
The Foreman re-sets the ESP system everytime you turn the ignition key off/on
Old Sep 7, 2008 | 10:45 PM
Hank5697's Avatar
How do you reset the rubicon so it will shift correctly. I'm stuck in a high gear will not shift down-up in either d1-d2 or esp. And while in reverse it sputters sometimes, almost sounds like its hitting the rev limiter but its not just sputters like that.
Old Sep 8, 2008 | 07:28 AM
Is the Rubicon not flashing a code ..?
Old Sep 8, 2008 | 11:28 AM
Hank5697's Avatar
flashing codes 5 & 6, thats the angle sensor codes. What to do next?
95wolv
Sep 27, 2024 12:00 PM
Johnny Mac
Aug 15, 2019 03:13 PM
mark23
Oct 1, 2015 09:57 AM
panicmanic
Sep 28, 2015 12:59 PM
