Big Bear Hard To Start
Old Sep 2, 2008 | 10:18 AM
7shortmag's Avatar
Default Big Bear Hard To Start
I have a 99 Big Bear 350 that is hard to start when hot.
Just had a new timing chain installed and valves set.
What to look for?
Thanks
Old Sep 7, 2008 | 07:25 PM
cadillacdude1975's Avatar
i have the same ATV. mine drags now and then when it is hot, but seeing how you have had work done recently, i would go back over and recheck the timing and the valve lash to make sure both are correctly set. if ATV cams are like some car cams, you may have to readjust the valve lash after a certain period for it to run correctly. if the timing is off by a couple of degrees, that would make it hard to start when hot too not too mention causing it to run an incorrect fuel mixture as well.
Old Sep 23, 2008 | 11:19 AM
7shortmag's Avatar
Well......I found the problem. I had the carb off for a rebuild and noticed a wire hanging loose near the frame on the left side. It looks like a ground for the starter. The only place it could have come from was under one of the bolts on the side engine cover. I suspect this was taken off when the timing chain was replaced and was missed when put back together. I finished the carb rebuild and replaced the wire. Now just touch the starter button and the engine is running. It took me 3 months to find this! lesson learned.
Old Sep 24, 2008 | 09:26 AM
thanks for posting about your solution. some people do, some dont. its nice to know what the problem was.
MikeyBoyesq
Nov 27, 2020 02:44 PM
buckshit
Sep 24, 2015 08:49 PM
Bulls
Jun 7, 2015 12:55 PM
1000gade
May 27, 2015 12:37 PM
dunc_n
Aug 26, 1999 09:32 PM
