2007 Wolverine 450 won't accelerate under load
Old Sep 2, 2008 | 10:08 PM
07wolverine05rincon's Avatar
Default 2007 Wolverine 450 won't accelerate under load
Okay experts...my 2007 Wolvy will start and idle like a champ, but it will not accelerate, especially if you open it up. Sputtering, popping, hardly ever stalls(but has), WILL NOT PERFORM. I cleaned filter, still doing the same thing. Can't be the gas because my Honda isn't doing the same thing with the same gas (although it is a Honda LOL).
Is it a dirty carb? Checked the carb vent line...clean. Gas cap vent line clean also.
Still under warranty...trying to decide if I need to take it in or should I expect them to try and rape me if it's only a dirty carb? I also have a service plan with them...routine maintenance included, not sure if dirty carbs are covered.
Any ideas what I should look for to fix this myself?
Thanks!
Old Sep 2, 2008 | 11:01 PM
tmichelli's Avatar
its prob the belt bro, i had the same issue but it did accelerate but did not have the torque is use to have... Have you ran it thru deep water? I had water and dirt on my belt and caused it to slip and not go near as fast. I took mine to the dealership easy fix. Costed me 100$
Old Sep 2, 2008 | 11:09 PM
If it was the belt, would it still sputter? Or would the engine still rev up, but no acceleration? Mine is not reving up...don't feel any slippage.
Old Sep 3, 2008 | 12:47 AM
tmichelli's Avatar
Like when u pull the throttle it doesn't rev?
Old Sep 3, 2008 | 04:11 PM
It would rev in neutral, but not in gear, forward or reverse, didn't matter, would sputter if you hit the throttle pretty good. It seemed like a dirty carb or air issue. After cleaning carb today, I cleaned all of the vent lines around the carb as well. One of them was not blocked, but restricted. As soon as I got it cleaned out, it ran like a champ again.
I hope this helps someone in the future.
Old Sep 3, 2008 | 05:59 PM
tmichelli's Avatar
Great, im glad you got your issue resolved. Sorry i wasnt any help.
Dewhound
Apr 20, 2017 02:25 PM
Sep 23, 2015 06:23 AM
ylomnstr
Sep 22, 2015 12:19 AM
braap123
Sep 7, 2015 12:58 PM
braap123
Sep 7, 2015 10:57 AM
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
