03 Predator kills when stopping
Old Sep 7, 2008 | 01:32 PM
bigbuffs's Avatar
Default 03 Predator kills when stopping
I have an 03 Polaris predator and just recently it started killing when idling. Also when I'm driving around and I need to stop it will often kill as I stop. If I stay on the gas a little it will stay running but otherwise it usually kills. I increased the Idle which helps when I start it up and I also changed the spark plug but It is still killing on me. Any ideas on whats going on?
Old Sep 7, 2008 | 08:27 PM
Rowe's Avatar
My buddies 05 is doing the same thing. He has the idle turned up real high on his so it stays running but so far thats what he figured out that works. Let me know if you find a solution, and I will too but I don't think he really cares and doubt he's gonna put any money into it to fix the problem unless he finds out exactly what it is!
Old Sep 9, 2008 | 06:19 PM
bigbuffs's Avatar
well I'm planning on selling it and I want to make sure that its gonna run good. If I were gonna keep then I would just crank up the idle and run it like that. Anyone have any ideas?
Old Sep 9, 2008 | 08:25 PM
Freaksh0w's Avatar
http://www.hpd-inc.com/Techtips1.htm
Does that sound like it could be the problem?
Old Sep 10, 2008 | 08:43 PM
bigbuffs's Avatar
I don't think so because it doesn't just shut off without warning it does it only when I'm stopping and if i keep the accelerator pushed in a little it wont kill
Old Sep 12, 2008 | 05:01 PM
Rowe's Avatar
Have you tried adjusting the ETC. If not turn your idle back down and tighted the adjustment, it's on the cable coming out of the ETC box and has a rubber boot covering it. Slide the boot and tighten the cable so it has about 1/8" play in the thumb throttle. This might be whats wrong. I'd give it a try anyway.
The only problem is that if that was the case turning up the idle wouldnt make a difference but it is worth a try
Old Sep 15, 2008 | 09:25 PM
bigbuffs's Avatar
Im not sure what your telling me to adjust. I didnt see anything in the etc box to adjust but I did adjust the throttle a bit and that seems to help. Its not killing when I stop know but It is still chugging a bit like it might kill.
Old Sep 16, 2008 | 08:45 AM
Rowe's Avatar
The adjustment isn't in the ETC box its on the cable. Thats probably what you already adjusted.
Hankey Pankey
Jul 31, 2015 05:50 PM
Hankey Pankey
Technical and How-To Articles
Jul 29, 2015 10:57 PM
1966F100
Jul 14, 2015 12:19 PM
1966F100
Jul 12, 2015 03:08 AM
steveo612
Jul 11, 2015 08:35 AM
