250ex upgrade
Old Jan 29, 2001 | 08:39 PM
Muddog1's Avatar
Could you upgrade a 250ex to 300+ccs? Would it be too heavy or give tooooo much power to the machine?
Muddog
Old Jan 30, 2001 | 09:03 AM
ATVer14's Avatar
Hi Muddog1. Where's Penfield? I'm about an hour out of Chicago. Do you have the 250 yet? I'm getting one this summer and I'm looking for all the input I can get.
Old Jan 30, 2001 | 10:20 AM
DSAPP's Avatar
The 250EX's main weakness is handling, not power.
We just bought a 250EX last week, it's not too far behind a 300EX as far as pep goes; but the handling differences are very noticable...
It's a little shorter and narrower than a 300EX and the shocks are non-adjustable with an inch less travel than a 300EX.
The first things we're gonna do to ours is:
- get some aftermarket front shocks
- put 400EX tires on the rear
- put wheel-spacers on all fours
- remove the airbox lid and re-jet accordingly.
... if that's not enought improvement for you, then you can always get a header/pipe and rev kit.
But if you're planning on boring it out already, why not get a 300EX or 400EX???
the only thing left to do is bore it
Old Jan 30, 2001 | 10:45 AM
94DGblaster's Avatar
if its that bad why don't you trade it in and get a recon? or a 300ex...if you are putting that much cash in it..
Old Jan 30, 2001 | 06:39 PM
BornToRace's Avatar
Hey DSAPP is it worth the money to get a 250EX or should I get a 300EX?
Old Jan 30, 2001 | 08:42 PM
Muddog1's Avatar
Penfield is in central IL. I am not gettting a 250ex unless i found out a way for more power.
Old Jan 31, 2001 | 01:23 PM
DSAPP's Avatar
if you're a casual trail rider, I'd get the 250EX
because it has no clutch, easier to use reverse, no chain to adjust or wear out, a better snorkel-type air intake that's more forgiving in water crossings, and better ground clearance.
if you're a more agressive rider, I'd get the 300EX because it has more suspension travel, a wider stance, and more power! I'd at least get rid of the balloon rear tires though
jankerstien
Sep 21, 2015 03:09 AM
Bonzhonda300ex
Sep 17, 2015 10:44 AM
Brandon400
Sep 5, 2015 08:44 PM
hondarider1234
Jul 21, 2015 11:53 PM
cSchwartz
Jul 9, 2015 02:40 PM
