gaptor 660 charging problem
Old Sep 9, 2008 | 01:47 AM
Dyce51's Avatar
Default gaptor 660 charging problem
I have a 2003 raptor 660 that does not charge at all. I checked the output at the stator and got about 16 volts AC at idle. Might be a little low? I checked to make sure none of the wires exept ground did not go to ground. I switched the regulator out for a different one and that made no difference either. I suppose it is a possibility that the other one may be bad but i do not suspect it is. Is there a way to test that? Does anyone have any other ideas that i may have overlooked that could be causing the charging problem? I also checked the 2 fuese and battery cables and all looked good there as well.
Thanks
slowgsxr97
Mar 18, 2022 03:40 AM
bzdok1234
30
Feb 23, 2016 01:55 PM
hondarider1234
Jul 21, 2015 11:53 PM
200es
Jul 19, 2015 04:50 PM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
