oil question
Old Sep 10, 2008 | 08:28 PM
500H.O.'s Avatar
Default oil question
After i drain it out of the engine and the jug, were do I put it back in the engine at to prevent a dry start. Do I just fill the oil jug & that's it ?
Old Sep 10, 2008 | 10:24 PM
Pour in 1 3/4 quarts in tank,IF worried,Just clamp off vent line at TOP of oil tank about 1 inch out,let run for couple minutes at idle,release pliers/clamp from hose,check oil on dipstick(screwed all the way in) Top off to full mark. SHOULD take right at two quarts. Only time I prime(clamp off vent line) is when I clean screen on oil tank. I dont clean screens religiously,only on machines THAT I KNOW have not been given REGULAR service. SLIGHT difference in capacity of metal oil tanks versus plastic tanks,thats why I dont just dump in 2 quarts.
Old Sep 11, 2008 | 01:28 AM
500H.O.'s Avatar
I am switching out my plastic tank w/ a metal one because the plug stripped out. The dipstick location is a little different but all the mounts are the some. Do the metal tanks hold more oil, and how often should I service my machine?
Old Sep 13, 2008 | 09:13 PM
I do oil changes from a 2 quart jug I pump from our shops 55 gallon drum of PS4 Plus. Most of the time,metal tanks hold exactly 2 quarts with sump drained,and the plastic tanks almost always just a tad bit less!,BUT both are supposed to hold 2 quarts. AS LONG as you are between the low and high mark on dipstick its ok! I recommend at least twice yearly oil changes and an annual service of ALL fluids. A lot depends if pleasure or business/farm ranch use. On the heavy use machines I recommend 50 hrs,but I KNOW that comes quick on these machines and usually depends on owner as to when they service. Have had a few that didnt realize 2 quarts is cheap insurance compared to ground down cam lobes! Just use common sense on your service and 500 engine should last a long time. Good luck
Old Sep 13, 2008 | 10:48 PM
onesavage's Avatar
mobile 1 0w-40 , is this ok..thats what i have been useing..
Old Sep 13, 2008 | 11:01 PM
OK to use.
Old Sep 14, 2008 | 08:12 PM
500H.O.'s Avatar
I changed the oil and filter, I found 0w-40 oil at oreillys it was royal purple band synthetic. It's a little cheaper than the polaris oil. The machine is still smoking, i did not run it long. I didn't want to mess it up even more. I reckon i'll have to rebuild the engine now.
Old Sep 14, 2008 | 09:14 PM
onesavage's Avatar
was it smoking before, were you trying to fix a issue with the oil change?
Old Sep 14, 2008 | 09:34 PM
back41's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: old polaris tech
Only time I prime(clamp off vent line) is when I clean screen on oil tank. I dont clean screens religiously,only on machines THAT I KNOW have not been given REGULAR service. </end quote></div>
I've got a 2001 500HO with 2500 miles on it that I clean the screen on everytime I change oil, usually once a year. I've never done that priming thing. Why do you do that? It's not mentioned in the manual.
That being said, the only time I ever found debris in the screen was as a few metal shavings the first time I changed it.
The thing runs just as good as the day I bought it.
Old Sep 14, 2008 | 10:06 PM
500H.O.'s Avatar
The machine runs like a top, it just smokes. It's been sitting for the last month or so b/c the water pump seal was leaking. Well after I got the seal replaced and started it up it was smoking. It has never ran hot. I had put 10w-40 in it and some folks said that may have been the problem, so I changed the oil and filter w/ the 0w-40. Now it is still smoking.
Alex G.
Sep 11, 2017 11:38 PM
EIF
Apr 20, 2017 07:15 PM
Ahtatu
Sep 28, 2015 12:14 PM
2many2ride
Sep 27, 2015 04:35 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
