need help
Old Sep 14, 2008 | 07:17 PM
lisa 2004sportsman's Avatar
Default need help
2004 polairs 400 runs god ,cranks good , untill you get on it or you go up a hill. with the breather tube off the carburetor, it runs good .what can be wrong
Old Sep 14, 2008 | 08:09 PM
700 sportsman's Avatar
Default need help
its too rich by the sounds of it
try adjusting the air/fuel mixture screw
Old Sep 14, 2008 | 09:26 PM
Speeddrive1's Avatar
Default need help
the air mixture screw only adjusts the idle mixture. When was the last time you cleaned the air filter? I would start with that and then check for any vent tubes that they are connected to the carb and not restricted in any way.
Old Sep 14, 2008 | 09:41 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
Default need help
<div class="FTQUOTE"><begin quote>Originally posted by: 700 sportsman
try adjusting the air/fuel mixture screw</end quote></div>
yep. so check the float as well to make sure its set right, as well making sure the air filter is clean. imo.
Old Sep 14, 2008 | 10:07 PM
Default need help
took the breather box and tube to the carb off .hooked only the air filter up to the carb and it runs great. with the rubber tube to the breather box hooked up it boggs so whats up with the rubber tube?
Old Sep 14, 2008 | 10:18 PM
Default need help
that causes there to be less air, there fore there is too much fuel and not enough air
Old Sep 14, 2008 | 10:25 PM
Default need help
polaris dealer worked on it, raced the float still wasnt right . took to another he lowered it . now it only does it when it gets hot .its runs good till then
