HOT WARRIOR
Old Sep 14, 2008 | 08:02 PM
zz8t's Avatar
Default HOT WARRIOR
hi guys i have an 01 warrior that gets extreamley hot. when i sit on it my legs start to sweat and i cant ride for to long because the heat gets unbarable. yesterday wile i was watching my friend hit this jump my quad was idiling and all of a sudden it died so when i tried to restart it it wouldent work so i looked at the starter and it was smoking hot i dont know what wrong and why i gets so hot
Old Sep 14, 2008 | 08:51 PM
blackburn's Avatar
Default HOT WARRIOR
Here's a few things that cause excessive heat:
Incorrect spark plug gap or heat range
bad CDI-timing
incorrect oil level/viscosity
bad oil pump
clogged air filter
incorrect jetting
bad head gasket
carbon build up in combustion chamber
also does the quad coast freely or is something dragging(bearings/brakes)
Old Sep 14, 2008 | 10:05 PM
zz8t's Avatar
Default HOT WARRIOR
thanks for the quick response the quad coasts fine
Old Sep 15, 2008 | 01:38 AM
2Owanage's Avatar
Default HOT WARRIOR
My warrior run hot i never thought anything of it yea my legs sweat but its also a combustion chamber 8 inches from you legs
Old Sep 15, 2008 | 06:11 PM
zz8t's Avatar
Default HOT WARRIOR
yea but mine gets so hot it wont start like if i wash it off and get it soaked it will have steamed off all the water after a minute of running my lt230 takes 15
Old Sep 16, 2008 | 06:45 PM
bassballs818's Avatar
Default HOT WARRIOR
I'm trying to figure out why my 03 warrior runs hot. It runs fine but gets hot in seconds of starting, but i cant tell if its because i havent been on it in a while or if it is really to hot. I've gone through all the motions.
Does anyone have a clue what the round about running temp should be for a warrior????
Old Sep 17, 2008 | 11:52 AM
ATV24/7's Avatar
Default HOT WARRIOR
Don't wash it right after you ride!!!!! Wait until it cools down. It will steam if it is hot like that.
Old Sep 17, 2008 | 12:22 PM
Default HOT WARRIOR
OF cousre, you will see steam when you ride through puddles too or get hit with any water for that matter
Old Sep 17, 2008 | 05:02 PM
zz8t's Avatar
Default HOT WARRIOR
no i wate till its cold then wash it then after when i start it up to drive it to the shed
all the watter gets steamed off
like bassballs818 whats the avarge running temp for these things
Old Sep 22, 2008 | 10:05 PM
Spyd3rV3nom's Avatar
Default HOT WARRIOR
it's an air cooled motor, it's gonna get hot. get used to it.
if it's that unbearable switch to a heavier oil in the summer.
