01 wolverine
Old Sep 18, 2008 | 09:02 AM
warrior1989's Avatar
Default 01 wolverine
it starts to idle high when in nuetral...wats wrong?
Old Sep 18, 2008 | 09:56 AM
mechanicock's Avatar
cracks in the rubber boot that goes from your carb, stuck/barbed throttle cable, dirty carb my warrior did the same thing and if you have a wolverine 350 then its the same motor.
Old Sep 20, 2008 | 11:35 PM
sentinal02's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: mechanicock
cracks in the rubber boot that goes from your carb</end quote></div>
would check this one quite thoroughly before diving into the carb. I just bought an 02 with this problem. turned out to be the rubber part of the intake manifold peeling away from metal that bolts to the cylinder. if no cracks are visible, gently try and peel the rubber away and see if it comes loose.
Old Sep 23, 2008 | 09:49 AM
i can put my hand over the rubber hose that comes out of the air box and it will idle back down but when i let go it idles back up
suzuki230
Jul 8, 2016 10:03 AM
Nelson
Jun 22, 2015 03:51 AM
Nelson
Jun 20, 2015 01:59 PM
ragewraps
May 27, 2015 08:07 AM
holmbergm97
May 27, 2015 07:23 AM
