01 wolverine
<div class="FTQUOTE"><begin quote>Originally posted by: mechanicock
cracks in the rubber boot that goes from your carb</end quote></div>
would check this one quite thoroughly before diving into the carb. I just bought an 02 with this problem. turned out to be the rubber part of the intake manifold peeling away from metal that bolts to the cylinder. if no cracks are visible, gently try and peel the rubber away and see if it comes loose.
