polaris predator 50cc
Old Sep 20, 2008 | 01:55 PM
dalewootton's Avatar
Default polaris predator 50cc
please can someone tell me how to derestrict my boys polaris predator 50cc? Would much appriciate if someone could give me some ideas thanks.
Old Sep 20, 2008 | 06:31 PM
On cdi module(black box above carb) pull down module off of bracket strap,should be small metal plate on end of module held on by two screws,loosen screws,slide u shaped piece of metal off. The limiter is removed then.Also can increase throttle by small screw on throttle assembly,loosen small 8 mm lock nut loosen screw to allow more travel on thumb throttle and re tighten nut. Good luck
Old Sep 21, 2008 | 06:20 AM
Thank you very much cheers mate
Old Sep 21, 2008 | 08:22 AM
Just took out that little u plate that connects the two screw on the cgi and it now goes like a little rocket cant thank you enough you know your stuff THANKS!!!!! [img]i/expressions/face-icon-small-smile.gif[/img]
firsttimerider
3) General Discussions..
Aug 9, 2015 09:54 AM
1966F100
Jul 24, 2015 02:17 PM
1966F100
Jul 14, 2015 12:19 PM
1966F100
Jul 12, 2015 03:08 AM
steveo612
Jul 11, 2015 08:35 AM
