2008 BF 750i radiator
Old Sep 20, 2008 | 04:41 PM
FeldaGirl's Avatar
Default 2008 BF 750i radiator
need to get to radiator cap. any easy ways
Old Sep 21, 2008 | 04:34 AM
monkeyboyy1's Avatar
http://www.motosport.com/offro...ar=2008&groupId=63827
this site shows it out of stock, but it may be due to them having to order it from the manufacture. give em a call to check it out. I get alot of my prairie parts from them and im very satisfied.
Old Sep 21, 2008 | 09:20 AM
bigpig750's Avatar
No easy way. Just how it looks you got to take the whole front plastic off. If you've got really small hands you may be able to get to it but not likely.
Old Sep 21, 2008 | 01:15 PM
my bad... I misread the question... I thought you needed a cap... SOWWY
Old Sep 21, 2008 | 02:34 PM
FeldaGirl's Avatar
Thanks for the help guys----it wasn't a piece of cake --but just took out bolt in bottem of radiator shield (or cover) and lifted it far enough to get hand in.
changed out fluid to engine ice.
Old Sep 22, 2008 | 09:04 AM
bigpig750's Avatar
I hope you did as suggested add flushed out the system with vinegar and distilled water! If you didn't know the mixing of the 2 different coolants will cause a gelling of sorts. this will in turn clog your cooling system. The heating of the 2 will be your rides undoing! Anytime you ever change coolants you should flush the system to get rid of any build up from water minerals.
Scooter's Shop
23
Oct 22, 2015 07:04 PM
35dodge
Sep 29, 2015 09:40 AM
rgjackson
Sep 23, 2015 01:53 PM
poutlaw525
Sep 9, 2015 03:19 AM
