No full throttle on Scrambler 500
Old Sep 22, 2008 | 08:57 PM
kanz24's Avatar
Default No full throttle on Scrambler 500
OK guys im lost. when im riding at 1/2 throttle the quad runs great, When i hit the throttle to wide open the bike falls flat on its face. So far I have changed the spark plug, Fuel filter and fuel pump with no luck. any ideas? thank you,
Jimmy
Old Sep 22, 2008 | 09:06 PM
Try pulling choke lever out a little at full throttle,see if helps.If does then possible main jet clog
Old Sep 22, 2008 | 11:03 PM
ftwflh's Avatar
If it isnt the main jet check the diaphram for a crack
Old Sep 23, 2008 | 05:17 PM
kanz24's Avatar
Thanks guys I will give these solutions a shot and let you know how I make out. Thanks,
Jimmy
Old Oct 19, 2008 | 08:34 PM
kanz24's Avatar
ok guys. I tried pulling the choke out when the bike starts to fall on its face at full throttle. It didnt make any difference. What do i try next?
Old Oct 19, 2008 | 09:02 PM
Checked for water in fuel system/carb? Water settles on bottom of carb and tank(just a thought) Running stock air box and filter? Pulled carb down,checked internals? Tank/carb vent lines clear,not pinched? Does it feel like bogging down or limiting(surging)?
Old Oct 20, 2008 | 05:14 PM
kanz24's Avatar
Its definitly bogging down. If I release the throttle when the bogging starts and I hit the throttle again it reaches full throttle no problem. I have a K&N airfilter. I havent pulled down the carb yet, I wanted to make sure that was the problem before doing so.
Jimmy
Jimmy
Old Oct 20, 2008 | 05:21 PM
If K&.N clean and oiled properly and still bogging,I'd check carb for contamination. Could just need cleaning or water might be present,FIRST drain carb line, if water present,will BEAD up on floor along with gas.
Old Oct 21, 2008 | 07:58 PM
kanz24's Avatar
ok I will try your suggestions this weekend. thank you
Jimmy
scram5050
Aug 30, 2024 01:39 PM
Sjrpp
May 2, 2023 03:59 PM
Sjrpp
Nov 15, 2019 09:59 PM
Sjrpp
Jun 2, 2019 07:25 AM
blpersinger
Jul 15, 2015 09:56 PM
