2008 Digital Speedmeter problems
Old Sep 23, 2008 | 09:58 AM
tower4269's Avatar
Default 2008 Digital Speedmeter problems
Has anyone had problems with the NEW Digital Speedometer on the 800 MAX? Mine gets moister inside when riding down the trails at low speeds. You can not even read the Speed or Tach. It only has 14 miles on it. I just wondering if anyone else has this problem.
Old Sep 23, 2008 | 11:50 AM
BioWare's Avatar
Toxic Ryder
Do you have a warrenty on it, I would take it back to the dealer to get fixed. to keep futher problems happing
Old Sep 25, 2008 | 12:04 PM
44MAG's Avatar
It happens, take it back for warrenty replacement.
Old Nov 1, 2008 | 04:29 PM
tower4269's Avatar
Can Am covered it with there warrenty. Thanks for the help!
Old Jan 15, 2009 | 08:59 AM
tunneldanny's Avatar
My 08 is doing the same, do you know what the fix was on yours?
Old Jan 15, 2009 | 10:22 AM
tower4269's Avatar
They replaced it under the warranty. Get it in ASAP. Other wise they have to replace the whole speedometer which is over $250.00. Mine seems to work fine. The mechanic said the seal had broken on the speedometer. Hope this helps.
Happy Riding, Ride Safe
Tower4269
Old Jan 16, 2009 | 07:31 AM
The dealer and I looked at a zoomed parts view of the display completely broke down and could not find any seal or gasket, The display does come from the factory with two small silica gel mositer packs placed inside the display.
The Dealer ordered two replacement packs and replaced mine.
He said if this does not correct the problem than BRP will approve a complete display replacement.
Sounds like a temporary fix to me, but I will just play along with the BS, until I get the new display.
Mine will only fog up when the sun comes out and hits the display while riding in cold mountain snow ( no sun never fogs). Never happens in mild weather were I live in the valley. Going to the snow this weekend so I will know if it works or not. Even if it stops the fogging I would think the silica packs will not last foreever.
Hopfully BRP has address this issue on 09 models?????
Old Jan 16, 2009 | 07:06 PM
raptoredd's Avatar
seems to be a common problem on the outlanders, not so on the renegade they have a sealed unit.
bzdok1234
30
Feb 23, 2016 01:55 PM
RedRancher
Jul 10, 2015 06:36 PM
traumajunkie
Jul 5, 2015 03:03 PM
D-Hagz
Jul 4, 2015 02:19 AM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
