New member intro and questions on '98 Magnum
Old Sep 24, 2008 | 12:57 AM
gjk5's Avatar
Default New member intro and questions on '98 Magnum
New member here, just wanted to introduce myself and ask a few questions.
Just bought a '98 425cc Magnum 4x4, this is my first ATV or anything of the sort, it had been sitting for a while so I want to know what I need to do to it to get it shipshape. So far I have on the list:
grease zerk fittings
oil/filter change
coolant change
air filter change
breather filter change
fuel filter change
tighten chain tension
figure out why lights don't work
Anything else?
I think I have the tensioning figured out (maybe) and I assume I can use my regular old grease gun for the zerks, any other advice is welcome.
I think I did OK on it, paid $1000. As I said it had been sitting for a while so it wouldn't start, I put in a new battery and plug and it still wouldn't start, another customer there told me he was a Polaris mech. and he took the carb apart, cleaned the jets and reassembled it and it fired right up. He said the engine sounded real good.
Old Sep 24, 2008 | 09:22 AM
Kerbbirds's Avatar
Check to see if its charging, hook a multimeter to the battery terminals while its running at like 2000 rpm should show around 14 volts , that may be what happened to lights if it quit charging or was run with a dead battery they will sometimes burn out the lights, if it's not charging its usually the voltage regulator located in front of radiator.
Old Sep 24, 2008 | 02:54 PM
gjk5's Avatar
Thanks, I'll do that. I'm gonna go run it in the desert a little today and continue with my checklist tonight.
TheATVSuperStore.com
TheATVSuperStore
Sep 9, 2015 07:43 PM
Bigtwin700
Sep 9, 2015 09:32 AM
Sep 9, 2015 06:57 AM
awer1968
Sep 8, 2015 11:02 AM
