engine troubles
Old Sep 25, 2008 | 10:59 PM
Snortwheeze's Avatar
Default engine troubles
we have a 96 425 magnum. it acts like it is in low gear (revs up no speed) really it is in high. Replaced front motor mount and it still does same thing. is there any other then the front and the back middle mount. the motor moves and 1.5 to 2 inches. any advice is helpfull
Old Sep 25, 2008 | 11:13 PM
Also motor mount on top right along with front and rear motor mounts. If revs up and no speed check drive belt and especially rear clutch ramp buttons for wear or damage,can cause problems. Good luck
Old Sep 26, 2008 | 06:15 PM
Found the top motor mount, everything seems in order, but there seems to be too much movement of the motor. Problem started when son was jumping with it. Next time he took it out, it wrecked the belt and put enough pressure on clutch cover to slice it on driven pulley. New belt, same thing, all rpms and not much speed. When looking down on clutch bolt, it appears to move .5 to .75 inches. What is normal? It's enough to cause filter to push on clutch cover. Also, how high up on the clutch should the belt ride at wide open? It only comes about 1/4 way up. Any ideas? Thanks
Old Sep 26, 2008 | 06:52 PM
Also just noticed, part no on new belt is 3211077 where as old belt is no 3211048 and appears a bit shorter, and a tad bit narrower(just wear?) Anyone know the correct belt?
Old Sep 26, 2008 | 09:51 PM
3211077 correct belt,you have the old original!
manuelrivera
Aug 8, 2015 04:34 PM
cornermike
Jul 30, 2015 06:37 AM
heath legg
Jul 24, 2015 01:01 PM
ltrmc02
Jul 22, 2015 04:50 AM
Desimation2k8
Jul 17, 2015 12:37 AM
