I BLEW OUT MY REAR END!!!
Old Jan 30, 2001 | 05:58 PM
littlesas's Avatar
I WAS HAULING WOOD WITH MY 99 BEARTRACKER AND I JUST GOT LOADED UP AND I WAS JUST STARTING TO MOVE AND MY REAR END JUST STARTED GRINDING AND I DIDN'T MOVE. I WAS WONDERING IF ANYONE MIGHT NOW WHAT THE PROBLEM IS AND ABOUT HOW MUCH IT WOULD COST TO BE FIXED...
THANX
"99 BEARTRACKER"
Old Jan 30, 2001 | 08:26 PM
BLH's Avatar
BLH
Happens to me every time I eat chili... oh you’re talking about your quad, we need more info to help, the grinding was were exactly? The Bear Tracker is shat drive right? Is the shaft turning? We need to locate the problem first.
Old Jan 30, 2001 | 08:54 PM
BONER's Avatar
First things first, check your rear end oil. Did it leak out? Is it white? What does it smell like??
After you do that come tell us what happen.
Old Jan 31, 2001 | 11:47 AM
RubiconBob's Avatar
Yes, please tell us how much grinding your rear end was doing. Also include if your rear end leaks, is it white, and does it smell? LOL!
Sorry, Boner, but I couldn't resist! I was thinking the same thing as BLH (about the chili), and I couldn't restrain myself! It just came out! ROTFLMAO
On the serious side, WAS there any oil in the axle? A bad seal would've let it leak it, and stop lubrucating the gears, which lead to their failure. If there was, and it was white, it would indicate that water got into your gears, so you have a bad seal, which has now lead to ruined gears in the axle. ALso, exactly how much wood did you pile on your BearTracker? Too much weight, and you may have snapped a tooth off in your rear end (ohh, no, that didn't come out right! ). I mean, you may have stripped a gear in your axle. Don't know about prices, and labor may be the highest cost. Good luck, and let us know....
Old Feb 1, 2001 | 02:51 PM
dand11's Avatar
Is the input shaft turning going in to the gear box? You may have sheared a pin or spline where the yoke slips over the input shaft. If it is an internal problem the costs shouldn't be too bad if you didn'd damage the gear case.
Dan
Old Feb 2, 2001 | 07:36 PM
ecorman1's Avatar
You guys are terrible! You scared 'sas away...
Nosniborpapa
Sep 12, 2015 05:54 PM
bmark0610
ATC 3-Wheelers
Sep 7, 2015 07:57 PM
bmark0610
ATC 3-Wheelers
Sep 7, 2015 07:48 PM
black_thunder
Sep 7, 2015 01:24 AM
