yamaha warrior not revving and backfiring
Old Sep 28, 2008 | 06:51 PM
Smokin'Guns's Avatar
Default yamaha warrior not revving and backfiring
Hello
I have a 2002 yamaha warrior which was always reliable until a few days ago. I went to start it after sitting for a while (2 weeks) and it will not rev at all. It will idle just fine then when i go to rev it it will pop and backfire then when i give it WOT it will stall. i cleaned out the carb, and put new gas in it and the problem is still there. The intake boot is brand new and the spark plug is new also. could it be a stuck valve or maybe electrical? any ideas?
Thanks
Jake
Old Sep 28, 2008 | 07:34 PM
dogbizkit's Avatar
unhook your parking brake switch. this is a common problem with warriors
Old Sep 29, 2008 | 06:55 PM
ljinx23's Avatar
x2, just got done fixing this problem with my 660 raptor. Disconnect it, and silicone the connector.
Old Sep 30, 2008 | 05:43 AM
beatwarrior's Avatar
all you have to do is unplug the white connector at the end of the wires coming from the clutch lever and if you want to override the switch while ur down there, its the switch that wont let you start it without the clutch in just unplug the two wires and plug the two wires on the harness together
Old Sep 30, 2008 | 06:50 AM
thanks everyone
i went up and did that last night and it ran just fine.
i didnt even know the warrior had a rev limiter on it! haha
STLyamwar
Jul 25, 2020 04:44 AM
manuelrivera
Aug 8, 2015 04:34 PM
Ashley S
Jul 31, 2015 09:46 AM
MATT BOOTH
Technical and How-To Articles
Jul 20, 2015 07:38 PM
MATT BOOTH
Utility ATVs
Jul 20, 2015 05:55 PM
