Raptor 350 Clutch Adjustment. Help!!
The clutch engages just before the lever is all the way out. I have the right clearance at the lever and the markings lign up at the case where it connects. The clutch is not slipping. Is it the springs?
That's just the way it is. If you don't like it you can give yourself some more slack in the cable at the lever.
Yeah the clutch is supposed to engage anywhere between 1/4 and 3/4 of the level motion..... you can fine tune it with the cable adjuster on the perch a little either way but it sounds like normal operation....
cdstang
Aug 31, 2015 07:52 AM
Aug 25, 2015 11:16 PM
Aug 21, 2015 01:23 PM
