SP500 clutch rebuild?? Got the creeps in gear
Old Oct 2, 2008 | 12:40 AM
79hugger's Avatar
Default SP500 clutch rebuild?? Got the creeps in gear
I pulled a buddy out a hole several days ago and since then I noticed my primary drive clutch is staying engaged against the belt causing it to creep at idle in gear and hitting the brakes stalls it.Is it time for a clutch rebuild? Polaris quoted me $425 for a new one
Old Oct 2, 2008 | 12:45 AM
eggenz7's Avatar
might have burned the belt a little bit causing it to be narrower. which would cause it to slide down in the clutch more creating a constant drag on the belt
Old Oct 2, 2008 | 12:54 AM
79hugger's Avatar
I got a new belt but had not thought about trying it, I did smoke the belt some.I'll give it a try in the morning
Old Oct 2, 2008 | 01:51 AM
user493's Avatar
Moto Psycho
I smoked a few belts really bad by trying to fit in between trees that were too close (trail maintained at 50" my a$$!!!) etc. All of them blew up about 100 miles later. If you didn't smoke it that bad, it probably won't blow up.
Old Oct 2, 2008 | 09:46 AM
scrambler400enoge's Avatar
Shapeshifter Rider
Nearly broke my ankle when my clutch BLEW UP on my scrambler the cvt cover came flyin off in to my ankle sounded like a big explosion had a bruise from my foot to my knee no joke don't let this happen to you!!I'll try and get some pics up
Old Oct 2, 2008 | 03:13 PM
Shapeshifter Rider
here http://i444.photobucket.com/al.../markrider400/001.jpg
http://i444.photobucket.com/al...markrider400/001-1.jpg
Old Oct 2, 2008 | 03:18 PM
psu111376's Avatar
Which clutch is "sticking" primary (front) or secondary (rear). If the primary is in fact sticking you might have mud/dirt in there. You will need to talk it part and clean it. If the primary is sticking a new belt will not fix anything, you will just burn up a new belt.
ghost civic
Jan 15, 2020 07:43 AM
kelleycully
Sep 15, 2016 02:57 AM
ghost civic
Jul 15, 2015 10:48 PM
200es
Jul 10, 2015 09:09 AM
coolguy420
Jul 10, 2015 01:17 AM
