DMC, White Bros. or Curtis Sparks
Okay I've narrowed it down to these three. I originally wanted to get a DMC. But I want to know if it'll really be worth the $500. And I really like look of the Sparks X4. The WB e-series won the Dirtwheels shootout. What do you think I'd benefit most from? If I get E-Series it would be the slip-on only. The other 2 would be the full system. I have a K&N and a 155 main from when I had my FMF. I want to feel a real difference in power.
Thanks for the replies.
Check out the March issue of Dirt Wheels. The did an exhaust shootout for the 400EX. The overall winners was the White Brothers series E pipe. It was tied for the most horsepower but is was significantly quieter than the other pipe. Not sure if the pipe you are interested in in the the shootout. There were about 10 pipes in the shootout.
I've heard the Sparks pipe is pretty good and I believe he wants 400.00 for it. I only had 2 pipes to choose from and that was the Sparks and the LRD. I went with the LRD and I like it ALOT!!!!
I have the sparks x-6(spark arrested) anyway the sparks and ct pipe are the same. by looking at my pipe and seeing the ct pipe on their site, I came to realize that they are the same. except for the fact that the ct pipe is $100 less than sparks.
if money not an object, get the pro yoshi full exhaust. at under 5lbs, it's lighter than my muffler alone. think about this, for about $600-$700. you get a full exhaust and a ten to fifteen pound weight loss.
if money is a problem, dg makes decent full systems under $400.
big gun sucks monkey poo.
pro circuit looks real sharp and very promising.
just remember that you will get larger gains with better air flow, more compression etc.
think long term, not what ever I can afford at the moment.
ron.
ron.
