700 EFI Oil Filter
Hello, new to the world of quads and this forum, hoping for help.
Recently purchased 2 new Polaris quads, a 500 EFI and 700 X2 EFI. After initial break-in I purchased oil and oil filters and proceeded to change the oil & filters on both machines.
I found the oil filter on the 700 to be extremely hard to access to both remove and install, any hints?
I use a plier type oil filter wrench,just reach in grab center of filter and break loose.Tight spot on the 700-800 engines. On install just oil gasket,turn about 3/4 turn after filter base lightly snugs up. Other members will probably give you their methods,just pick the easiest for you!
I use the type that fits over the end of the filter and uses a 3/8 ratchet to loosen or tighten.......You'll need to find one with a very thin wall because it is tight and the metal ones are a little better I think....
John
John
Thought this was a pretty good video explaining an oil change on a Sportsman.
Sportsman Oil Change Video
Hope this helps some...
biz
[img]i/expressions/face-icon-small-smile.gif[/img]
biz
Steeldon
Sep 9, 2015 09:38 AM
