700 EFI Oil Filter
Old Oct 4, 2008 | 11:24 PM
DigginD's Avatar
Default 700 EFI Oil Filter
Hello, new to the world of quads and this forum, hoping for help.
Recently purchased 2 new Polaris quads, a 500 EFI and 700 X2 EFI. After initial break-in I purchased oil and oil filters and proceeded to change the oil & filters on both machines.
I found the oil filter on the 700 to be extremely hard to access to both remove and install, any hints?
Old Oct 4, 2008 | 11:39 PM
I use a plier type oil filter wrench,just reach in grab center of filter and break loose.Tight spot on the 700-800 engines. On install just oil gasket,turn about 3/4 turn after filter base lightly snugs up. Other members will probably give you their methods,just pick the easiest for you!
Old Oct 4, 2008 | 11:43 PM
JCDEYO25's Avatar
I use the type that fits over the end of the filter and uses a 3/8 ratchet to loosen or tighten.......You'll need to find one with a very thin wall because it is tight and the metal ones are a little better I think....
John
Old Oct 5, 2008 | 12:31 AM
biz4two's Avatar
Thought this was a pretty good video explaining an oil change on a Sportsman.
Sportsman Oil Change Video
Hope this helps some...
biz
[img]i/expressions/face-icon-small-smile.gif[/img]
cswiger
Polaris Side by Sides
12
Oct 5, 2015 03:34 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
Steeldon
Sep 9, 2015 09:38 AM
black798
Sep 9, 2015 07:42 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
