Is this a clutch problem??????
Old Oct 6, 2008 | 08:09 AM
brianvabeach's Avatar
Default Is this a clutch problem??????
2000 Trailblazer 250 --
Seemed like jetting/carb problem. Have rebuilt carb and jetted to hotseat performance specs. Now what I get is.
When in Drive, you can nail throttle and it will just sit and sputter and eventually take off after about 30-45 seconds.
When in Reverse, you nail throttle and it responds great and takes off like a scalded cat.
Old Oct 6, 2008 | 08:11 AM
user493's Avatar
Moto Psycho
I'm no expert but I think that's a transmission problem.
Frank
Old Oct 6, 2008 | 08:16 AM
This is my first Polaris and first CVT, so not familiar with it, and honestly not impressed yet.
Old Oct 6, 2008 | 09:02 AM
Kerbbirds's Avatar
Push the over-ride button and try it, if it runs ok then unhook the black wire that goes to the overide.
Old Oct 6, 2008 | 01:29 PM
user493's Avatar
Moto Psycho
If you want something that will impress you then an 8 year old Trailblazer ain't it. [img]i/expressions/face-icon-small-happy.gif[/img]
Old Oct 6, 2008 | 01:33 PM
it was for my son (14yrold). I just didnt expect so many issues i guess since it is in great shape. Heck I have a Kymco 90 for my youngest and that thing has never given us a hint of trouble.
Old Oct 7, 2008 | 06:04 PM
hey KERBBIRDS!!
You may have hit it on the head for me.......but dont see a "black wire" going into the handlebar assembly. I have two connectors that plug into the left switch assembly. but neither has a solid black wire. Do you mean the solid black that goes to the actual limiter assembly near the oil tank?????
Old Oct 7, 2008 | 06:28 PM
dropin1984's Avatar
i would have to agree with jumbofrank, it sounds like a transmission problem. if i was you i would ditch the older polaris and get your son something he needs to shift. much more fun! good luck
Old Oct 7, 2008 | 06:33 PM
eggenz7's Avatar
polaris does not have a geared transmission. all that gear box does it reverse which direction the chain turns: forwards or backwards. the only way that it controls anything is from the rev limiter which is what it sounds like. there should be a black wire going to the rev limiter under the hood piece.
Old Oct 7, 2008 | 07:49 PM
ftwflh's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: brianvabeach
hey KERBBIRDS!!
You may have hit it on the head for me.......but dont see a "black wire" going into the handlebar assembly. I have two connectors that plug into the left switch assembly. but neither has a solid black wire. Do you mean the solid black that goes to the actual limiter assembly near the oil tank?????</end quote></div>
That is the wire to unhook.
Dont let these guys on here dog your 250 Trailblazer.Get it lined out and then with a pipe and matching clutch kit it will impress anyone.
