Is this a clutch problem??????
Old Oct 8, 2008 | 05:14 AM
user493's Avatar
Moto Psycho
Default Is this a clutch problem??????
I tried to eliminate in a few seconds anything that I didn't think could cause the problem, like a carb/jet issue. I didn't think the rev override <u>that isn't even suppossed to do anything in F</u> was the problem, when it didn't have a problem in R. I never heard of that happening before and it's a learning experience for me.
Old Oct 8, 2008 | 07:42 AM
brianvabeach's Avatar
I love the look and the sound of the 250 2 stroker. My son loves it because he is new to ATV riding and this way he doesnt have to worry about gears and clutch yet.
It does have a hotseatperformance exhaust kit / K&N filter / and re jetted. Seems like once I held in that override button it almost pulled the wheels off the ground.
Old Oct 8, 2008 | 07:59 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
it might be the trans switch is messed up if the override isnt working correctly.
Old Oct 8, 2008 | 08:05 AM
ftwflh's Avatar
I have seen reverse limiter cause all sorts of problems
Old Oct 8, 2008 | 08:52 AM
  #15
OK, I am guessing that when I cut this wire I will most likely not have the reverse light any longer correct???
Also, does anyone know if there is a kit to separate the braking. In other words have two brake handles. One for just front and one for the rear.
Old Oct 8, 2008 | 07:48 PM
  #16
ftwflh's Avatar
no need to cut the wire just unplug it.
HPD makes a split brake kit
Old Oct 8, 2008 | 07:51 PM
  #17
bmfpolaris700's Avatar
Does it have a low Gear? If so does it respond good?
Old Oct 8, 2008 | 08:08 PM
  #18
ftwflh's Avatar
Trailblazers and Scramblers have no low gear
Old Oct 8, 2008 | 08:10 PM
  #19
Ah yeah i feel like a idiot. YEa ill just stick to my sportsman ha my bad
Old Oct 9, 2008 | 08:39 AM
  #20
I unplugged the black wire going into the REV Limiter and that seems to be the issue. It runs like a scalded cat now. However I did lose the reverse light also. So, will pony up the 57.00 for a new limiter. Just so it is "right". Thanks all for the help and advise.
