How easy should it shift?
I recently bought a used 01 Sportsman 500 HO. I wonder how much "normal" effort is required to shift from N to R and from N to either L or H? It seems to me that it requires a little too much elbowgrease? I'm making the comparison to my friends 04 Grizzly which requires no effort to shift. Is there something that I could check or adjust to assure its normal for the Sportsman?
Thanks in advance,
Jocko
Thanks in advance,
Jocko
Does it creep when in gear? This is one thing that can cause hard shifting. if does then need to address this problem first (clutch). Another problem can be linkage out of adjustment!
Mine shifted very stiff, It gets used all winter and trailered a lot.
There are 2 or 3 Hyme joints and a non lubricated pivot up toward the front. I took every thing apart one link at a time and cleaned them up and relubed them with grease. I didn't adjust anything and now it shifts like new again.
I'll probably include that in an annual clean up.
exmotocrosser
Sep 13, 2019 06:12 AM
mrtidy
Feb 3, 2016 05:00 PM
