07 500 efi sportsman electric/battery problem
Old Oct 8, 2008 | 08:40 AM
Sultan's Avatar
Default 07 500 efi sportsman electric/battery problem
I have an 07 500 EFI sportsman, something is causing the battery not to keep a charge---the battery is good and will hold a charge but after 45 minutes or running wheeler a get a battery icon flashing. does anybody have any ideas? stator? regulator?.....i also have a friend that just bought an 08 800 EFI and he's having same trouble. Any help would be appreciated.
Old Oct 8, 2008 | 09:52 PM
Check with volt meter at battery to see if charging 14-14.5 volts,IF is load test battery. Have had some batteries bad straight out of the box or fail within a short time. If not charging or not charging enough,may have to trouble shoot .
Old Oct 8, 2008 | 11:22 PM
Beefcake35's Avatar
I was having the same issue with my 07 500 EFI. I have just shipped my stator out to get rebuilt. Mine was not charging 100 %. If you are not up around the 15v level you can check your stator by Disconnect your stator and measure 3 yellow wires to each other with a volt meter. All 3 should be pretty much the same. I only had 1 bad lead on mine, but my problems sounded just like yours.
skittero
35
Mar 1, 2019 12:39 AM
yellowpolaris
Jun 21, 2015 11:13 AM
UPLou
Jun 7, 2015 09:42 AM
May 27, 2015 11:15 AM
PolarisPower500
May 17, 2015 02:28 PM
