250 2001 polaris trail blaser will not start
Old Oct 8, 2008 | 12:03 PM
mikesbikesmalden's Avatar
Default 250 2001 polaris trail blaser will not start
ok here is the deal a customer brought in a 2001 250 polaris that would not start it had low compression. i pulled the cylinder off and had the machine shop bore the cylinder reinstalled it and it will not start? has good compression i checked the piston before i put it in. it seems it is sucking at the exhaust side and spitting on the intake side. i used a namura piston the f mark to the flywheel. i also installed new bottom end seals.
Old Oct 8, 2008 | 07:19 PM
eggenz7's Avatar
try a leak down to see if there are any vacuum leaks
Old Oct 8, 2008 | 07:55 PM
done that no leaks it is blowing air out the intake sucking on the exhaust
Old Oct 8, 2008 | 10:53 PM
eggenz7's Avatar
its going to do both blowing and sucking on both the intake and exhaust. since there are no mechanical valves to stop the wrong action, it will do whatever the piston is trying to do till the skirts block off the appropriate port in tthe jug
Old Oct 8, 2008 | 11:11 PM
ftwflh's Avatar
SOunds like you have the piston in wrong.Most pistons are marked to go to the exhaust.
Old Oct 8, 2008 | 11:12 PM
eggenz7's Avatar
numara pistons have a f that goes to the flywheel side. he put it in right
Old Oct 9, 2008 | 12:11 AM
<div class="FTQUOTE"><begin quote>Originally posted by: ftwflh
SOunds like you have the piston in wrong.Most pistons are marked to go to the exhaust.</end quote></div>
yep your right...
skittero
35
Mar 1, 2019 12:39 AM
Big600twin
14
Jun 16, 2015 09:30 AM
FourWheelOverTwo
May 31, 2015 07:26 PM
PolarisPower500
May 17, 2015 02:28 PM
Rod
Oct 4, 1999 12:37 PM
