2005 DS650X
Old Oct 8, 2008 | 06:51 PM
DS650X2005's Avatar
Default 2005 DS650X
I DISSASEMBLED MY CARB TO CLEAN IT. I TOOK OUT THIS NEEDDLE PIN OUT AND NOW I DON'T KNOW HOW MANY TURNS IT TAKES TO LEAVE IT WHERE IT WAS BEFORE. WHEN I TURNED IT ALL THE WAY OUT THE PIN CAME OUT AND A SPRING. IF I TURN IT ALL THE WAY IN I CAN SEE THE PIN STICK OUT THROUGH THE CYLINDER AIR PASSAGE...HELP!!!!
Old Oct 8, 2008 | 07:35 PM
jusrlax's Avatar
Default 2005 DS650X
Not sure what you mean by "needle pin". Are you referring to the needle that fits into the slide that goes into the top of the carb? If you can describe what you are referring to a little more clearly, I'm sure someone will try and help you.
Old Oct 8, 2008 | 08:12 PM
SilverBomb's Avatar
SilverBomb has got an Addiction!
Default 2005 DS650X
Are you talking about the stock Mikuni 42mm? I don't know what you mean by turning it out or in. They should be held in by a clip that comes off and goes back on. You'll need to give us more detail and maybe pics.
Old Oct 8, 2008 | 10:41 PM
YAMASUXHONDUST's Avatar
Default 2005 DS650X
I would turn it all the way in and screw 2 1/4 out to start with stab the thumb throttle to see if it stumbles if you are talking about the set screw i would also use the run and check spark plug to see if lean or rich method white for lean black for rich and tan for about right
Old Oct 9, 2008 | 02:17 AM
TheStir's Avatar
Started riding ATVs in 1974!
Default 2005 DS650X
Set your screw around 1.5 turns out. Once warm and idling - slowly turn it out until RPMs drop, them slowly turn it in until the RPMs drop and set the screw between these two point.
Old Oct 9, 2008 | 09:32 AM
aceisback's Avatar
Military Rider
My hobbies are NASCAR, Rockin' in the Free World, and riding my Sand Pigs at every available opportunity.
Default 2005 DS650X
WOW! So many answers with so many options. So we've got ideas on the idle adjustment screw, the air/fuel mixture screw, and the needle for the main jet. Wonder which one it will turn out to be??? I was leaning towards the needle myself and have to concur with John that the clip is what moves the needle in or out.
I'll check back later to see where this goes.
aceisback's Avatar
Military Rider
Default 2005 DS650X
Old Oct 12, 2008 | 12:39 AM
baja02's Avatar
Default 2005 DS650X
ya man, 1 1/2 turns out. you mean the air/fuel screw. You wnt 11/2 tunrs out. tuurn the screw all the way in then back it out 11/2 turns. Thats what you use stock. and thats what you use jetted to the max. ex. 185-200 main jet.
Old Oct 12, 2008 | 12:40 AM
baja02's Avatar
Default 2005 DS650X
also its the best to run it on the 3rd clip down on the needle, hope I helped
salixair
Nov 3, 2015 08:25 AM
01ssls1
Sep 22, 2015 06:50 AM
Lou Domenech
Sep 11, 2015 06:35 PM
Brandon400
Sep 5, 2015 08:44 PM
