Help-carb re jetting
Old Oct 11, 2008 | 01:46 PM
albacore44's Avatar
Default Help-carb re jetting
Trying to remove the bowl screws and they are real tight phillips head just strips them. Tried using Vice grips, that don't work either. Thought about trying an easy out. any tips on removing these screws ??
Old Oct 11, 2008 | 02:49 PM
OMR's Avatar
OMR
Is Oldmanracing! Also the inventor on the DS650 carb Mod!
You do have the carb off the motor!
You can either use a needlenose vice grip or I have had good luck with a small 4" channel lock.
Remember to turn counterclockwise - to the left.
Old Oct 11, 2008 | 02:53 PM
DubaiPolaris's Avatar
916 Reaper - Pure Evil Inside!
Usually some small needle nose vise grips work when it gets that bad. Have you tried cutting a slot to fit a flat head screw driver in the screw? Before I attempt to remove any of those OEM carb screws I put the screw driver in the screw and give it a couple of taps with a hammer and that seems to help and using a screw driver that has a black coated tip, seems to help as well.
Once you get them out make sure you replace them with a socket type screw of your liking.
Chris
Old Oct 11, 2008 | 03:41 PM
albacore44's Avatar
well, no, haven't figured out how to remove the throttle/choke cables at the carb off yet. loosened the barrel nut, but not sure how to get the cable loose.
Old Oct 12, 2008 | 02:05 PM
cynick's Avatar
It takes 2 small screwdrivers. Open the carb all the way and hold it open with one screwdriver. Take the other one and fish the cable and ball out of the holder. Be careful not to loose the end that goes to the carb. It can get lost easy.
Old Oct 12, 2008 | 06:15 PM
baja02's Avatar
ya i played with my carb for a day or two, try tapping the screw driver with a hammer, be sure you dont break the carb, its like white metal, soft, it breaks easy. Go to your local shop and get the same screw but with a alen/hex head. You will never have that prob again.
They do make them, its sweet if your cleaning you carb alot.
Old Oct 12, 2008 | 07:12 PM
albacore44's Avatar
alright, got the screws out, rejetted, replaced with new screws.started her up, sounds good, however , now I got fuel leaking off the bottom of the bowl. back to the drawing board.
Old Oct 12, 2008 | 11:54 PM
cynick's Avatar
Your floats got bumped up so the bowl is overflowing out the overflow and going out. I did this very thing when mine had a stock carb on it, dumb mistake but easy fix. The floats are set too high. remove the bowl and pull them down a little bit.
Old Oct 13, 2008 | 12:07 AM
aceisback's Avatar
Military Rider
My hobbies are NASCAR, Rockin' in the Free World, and riding my Sand Pigs at every available opportunity.
Ditto what cynick said. We've all done it! Check out the OMR summary and it will give you the perfect setting for the float and have that thing popping wheelies in no time.
ReconBayou
Oct 31, 2022 05:37 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
XxS0ccerstarxX
Sep 8, 2015 12:02 AM
