awd help
Old Oct 13, 2008 | 11:10 AM
michael l's Avatar
Default awd help
i have a 05 800 sportsman twin. In rev. 4wd did not work when i got the 4 wheeler.. Yesterday i went mudding and 4wd stoped working. I set it up on blocks and the front drive line turns in 2wd and in 4wd but the front tires will not turn at all. can anybody help with this. also i think i have a cv joint going out in back right tire. need help with this too.
Old Oct 13, 2008 | 11:18 AM
pokerman11's Avatar
Default awd help
Just checking that you know that in 4wd does not work in rev - unless you are holding/pressing the rev overide switch. I assume you know that, but can't hurt to double check.
(You can override this function - I did as I do a lot of plowing)
Another simple thing is that perhaps your issue is electricial. Take a look at the 2wd/4wd switch - ensure the molex plug is seated properly, perhaps take it out and clean. I have an 00 SP and and 08 SP (800) - had issues with these switch plugs. I would suggest to first look at electrical
As far as the right rear joint - why you think it is going out?
Old Oct 13, 2008 | 11:28 AM
michael l's Avatar
Default awd help
yes i know that i have to hold down the overide switch, but it still does not work i will check the 2wd/4wd switch when i get home today but if that is not it then what? the front end???
right rear joint-it has started poping when i back up or when i make a sharp turn..
Old Oct 15, 2008 | 07:07 PM
michael l's Avatar
Default awd help
checked the 2wd/4wd switch plug.. i unpluged it cleaned it and pluged it back in and still nothing.. any info?????
Old Oct 15, 2008 | 08:30 PM
eggenz7's Avatar
Default awd help
maybe the roller cage is broken on the front differential? dont know much about it. just passing on info from what ive read on here before. maybe old polaris tech will chime in.
Old Oct 15, 2008 | 09:39 PM
Default awd help
Most of the problems on the earlier front gearcases I've seen are roller cage damage and seal leakage.
Old Oct 16, 2008 | 08:23 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
Default awd help
chances are if the awd light is on and no awd then the cage is the issue. imo.
Old Oct 16, 2008 | 11:41 AM
michael l's Avatar
Default awd help
don't know much about this kind of thing.. what is the roller cage?? is the roller cage the front end and if so how hard is it to fix?? any pictures on fixing this?
Old Oct 16, 2008 | 12:11 PM
TLC's Avatar
TLC
Default awd help
<div class="FTQUOTE"><begin quote>Originally posted by: michael l
don't know much about this kind of thing.. what is the roller cage?? is the roller cage the front end and if so how hard is it to fix?? any pictures on fixing this?</end quote></div>
http://216.37.204.206/wps/Pola...asp?Type=13&A=431&B=29
#8 $231
John Deer has a stronger metal one that works,you can look up the part # at High Lifter,s web site they seem to use those once the cheap polaris plastic cages explode.
Old Oct 16, 2008 | 05:31 PM
700 sportsman's Avatar
Default awd help
Heres the john deere info
