carburetor throttle valve
There is a pin that goes on the inside of the carburetor that sits in place to make sure the throttle body goes up and down on a straight path. What is this pin called? Where can i get a replacement and how much do they cost?
I think what you're referring to is the "needle". A cv carb doesn't have a throttle body but the "needle" does go up and down within the "slide". You can get a new one from your local dealer. Is it a stock carb and what kind of bike and year are you talking about?
no its not the needle. The needle sits inside the throttle body. I have a yamaha banshee. but what im looking for should be some kind of pin, i pulled it out yesterday and it was in bad shape
Look here: http://www.powersedge.com/page...wbybrand/default.aspx
SKU: 2GU-2633K-00-00
WIRE, INNER 1 2 $9.61
I think this is what you're talking about.
http://216.37.204.206/wps/Yama....asp?Type=13&A=208&B=1
What part from the above link are you talking about?
willday08111217@gmail.com
Technical and How-To Articles
Aug 1, 2015 04:05 AM
