2003 700 Flashing Battery Light - Need some assistance please
Old Oct 14, 2008 | 03:05 PM
AllPolaris's Avatar
Default 2003 700 Flashing Battery Light - Need some assistance please
My 700 died on me - I replaced the battery and I am still getting the flashing battery on the display and eventually it quits after several hours and I have a dead battery. Checked the connections, took them apart and cleaned them at the battery and voltage regulator - no luck.
I did put a new smaller battery in because I had broken down and thought it was the battery, but it still wore that one down to and have the flashing battery light in about 5 minutes.
Does anyone know how to check the stator output on this machine. I have a repair manual for my old 500 and its not very clear. Need to get this back up an running quick.
Thanks!
Old Oct 14, 2008 | 05:00 PM
02magnum500's Avatar
Gets his share of deer.
check to see if the battery is getting about 13vdc at idle. Do this with a Volt Meter put the red on positive and black on negative battery terminals. when engine is reved up it should be no more than 15-16 VDC. I suspect your system is not putting out a charge on the battery. The battery light shows a battery low voltage or a battery overvoltage, one or the other will trip this warning light, in your case it is the low voltage. Just my 2 cents.
Old Oct 15, 2008 | 12:02 PM
AllPolaris's Avatar
Think I have it figured out - my local Polaris Mechanic told me how to figure it out quick - measure between the yellow wires from the stator and you should see no less than 30v AC, anything below that is unacceptable. I had almost 40v AC so the stator was not my problem, measured the output from the regulator and I was only getting 2.8v DC, so looks like I have a bad voltage regulator - $109.00.
slowgsxr97
Mar 18, 2022 03:40 AM
bzdok1234
30
Feb 23, 2016 01:55 PM
KimSJoh
14
Jul 18, 2015 07:20 PM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
