2007 Grizzly
Old Oct 14, 2008 | 05:58 PM
2FAST4URASS's Avatar
Default 2007 Grizzly
I have a 07 Grizzly and the back Diff has started leaking it is a small leak BUTT!! a leak and I now have the seal and I was wondering does the axle just slide out or do I have to take the whole diff apart to replace this seal I see that there a little clip on the axle what is it's purpose? Someone PLEASE HELP I am past ready to ride again!!!
Old Oct 15, 2008 | 11:47 AM
CraZySteve's Avatar
Did you get the 2 year Warranty? This happened to my Grizzly 450... it was fixed under warranty...
I believe you can just pull the axle - replace the seal and you are good! Granted it takes a bit or work to get the axle out... I believe the Seals are different on either side too...
-Steve
Old Oct 15, 2008 | 09:27 PM
Nope no 2 year warranty.The leak is on the left side if you are looking at the back of it I looked at many sites but could only find a seal 4 the other side so i ordered it I HOPE HOPE HOPE it will work!!
Old Oct 16, 2008 | 08:17 AM
CraZySteve's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: 2FAST4URASS
Nope no 2 year warranty.The leak is on the left side if you are looking at the back of it I looked at many sites but could only find a seal 4 the other side so i ordered it I HOPE HOPE HOPE it will work!!</end quote></div>
Did you look at Bike Bandit?
Anyhow.. that is the seal that went on my Grizzly 450... they fixed it right up and it has been fine for over 400 miles now...
keep us posted
Old Oct 16, 2008 | 04:58 PM
Yeah Steve thats were I ordered it from I order all my stuff from them or rockymountainatv.com Im going out today and see if I can get it out. Thanks so verry much!!! for the help so far ill let you know when im done...
Old Oct 16, 2008 | 09:52 PM
WEEEEEEEH I got it Steve It is the same seal on both side's now I see why Bike Bandit only has the part number for on side!! Anyway's I went out sat the back end on a 5 gallon bucket took only the tire off and the 2-clamps that hold the brake line down and removed the 2-bolts that hold on the spindle and then put a large pipe clamp on the axle toward the end tightned it down for something to hit on and with a few good tap of my 3 pound hammer out it came the whole little deal I pulled the old seal with some neddle nose vise grip's and lubed the new seal and tapped it in and the got it togather and took it for a ride WITH NO LEAKS!!!! WEEEH THANK'S FOR THE HELP AND GOOD RIDING TO YA.. And if your seal was to go bad and you warranty goes out dont worry it is a brease problay one of the easiest fixes ive done in a whille..Thank GOD
cboler9
Sep 24, 2015 08:35 PM
Sep 23, 2015 06:23 AM
ylomnstr
Sep 22, 2015 12:19 AM
braap123
Sep 7, 2015 12:58 PM
braap123
Sep 7, 2015 10:57 AM
