07 grizz 450 engine help
this might sound really dumb but how do you check your the valve allignment, i have the cam sprocket lined up with the mark on the inside of the housing but this is the first time i have really gone this detailed into it so i am kinda lost
Ok check your crank mark to make sure its lined up then make sure your cam is lined up with the mark like you have it. When you are at TDC your valves should have a little play in the rockers if not then you are 180 out and need to turn the crank 180 and line it up again, then adjust the valves to the specified adjustment.
