87 Moto 4
Old Oct 20, 2008 | 12:17 AM
jbrose's Avatar
Default 87 Moto 4
I would appreciate any & all suggestions/solutions:
The keyswitch turns motor on(to start), but it does not kill it when "switched" to Off. (The killswitch doesn't either). I am assuming that the keyswitch is bad, but with the killswitch not working either, I wonder if it could be something else.
I hate to resort to "trial & error" with an ignition switch priced at $81.00!
Old Oct 20, 2008 | 01:10 AM
JNH632's Avatar
Default 87 Moto 4
I would check to see if the ingition switch has been bypassed. It sounds to me that someone ran an extra wire to do this. I would check for that first. If the switch is indeed bad, the light would either always stay on or always stay off. Look for an extra wire run to your battery.
Old Oct 20, 2008 | 01:33 AM
jbrose's Avatar
Default 87 Moto 4
Thanks for the reply/suggestion...I will check for a bypass wire, but:
(1) the "on/start" light turns on when it should be & goes off when key is turned off.
(2)Since neither the ignition switch nor the kill switch shut off the engine, I have to stop it by "choking" it.
Despite the start light working properly I am pretty sure the ignition switch is bad but didn't understand if the killswitch works "thru" the ignition switch as well, or if both need replaced.
Old Oct 20, 2008 | 12:19 PM
Endo's Avatar
Default 87 Moto 4
Bad ground?
Old Oct 20, 2008 | 11:49 PM
jbrose's Avatar
Default 87 Moto 4
I didn't get to mess with it today but will check that again tomorrow... I had tried to "kill it" with a jumper wire between the kill switch & the ground(used the ground side of the battery once and also the engine itself)but to no avail...
jbrose
wendal
Aug 3, 2024 10:03 PM
scman843
Jun 18, 2017 10:21 PM
fredrikrosen
Oct 29, 2016 07:56 PM
zPuls3
1) Engine problems..
Sep 12, 2015 08:54 AM
mrmickman123
Technical and How-To Articles
Aug 30, 2015 10:37 PM
