dual carbs on my banshee
should i get a set of dual carbs on my shee? i have a 40 mm lectron single carb right now, but it doesnt seen like it has that much low end. i think 40mm is too small for a shee. cause it back fires when you hit it all the way when you start out.
are the shee carbs like 35mm each or together? i was looking at a set of 35mm on ebay and i like them but i dont know because the guy i bought it from said it was on big one instead of two small ones, but i dont know
so im guessing i'd be down mm with the 40 mm? it runs good but i was looking for more power. it has pipes, power reeds, new head, .50 pistons, new clutch. so it has most of what you can do to the motor done to it,but porting and a stroker crank.
Jul 7, 2015 11:00 PM
